I have had this Blazer for several months and no shop can tell me what's wrong ! Everyone says have the fuel pump checked ! Only way this Blazer will start after sitting a couple hours is to spray starter fluid in the throttle body and once it cranks it runs like a brand new car never misses or cuts out ! It has fuel pressure through the lines and fuel filter is not stopped up ! We have been cranking it for 2 months this way and afraid of hurting the motor ! Please help ! ! !
SPONSORED LINKS
Monday, August 3rd, 2009 AT 12:58 AM
MECHANIC
I recommend that you actually check the fuel pressure with a fuel pressure gauge designed for your fuel system and then comeback with the readings -
