1999 Chevy Blazer Engine wont turn over
C.PENTASUGLIA
  • 1999 CHEVROLET BLAZER
Engine Mechanical problem
1999 Chevy Blazer 6 cyl Four Wheel Drive Automatic
My brother has given me a Chevy blazer that has a few issues. His mechanic could not figure out what was wrong with it. Everything in the truck works well accept it wont start. I turn the key and I hear the fuel pump come on(no problems with it). But when the key is turned to start the vehicle absolutely nothing happens. I also hear a few ticks from within the dash under the glove box basically. Ironically my brother said before the truck would start every so often, but only when the daytime running lights came on. I dont know if there is a correlation but I though maybe that info could help. Im wondering if maybe it could be the ignition relay? Or maybe a line going to the vehicle computer? Any ideas please help
Sunday, August 22nd, 2010 AT 9:09 PM
Make sure the battery and connections are good if okay short out the starter solenoid battery terminal to the small terminal that has the purple wire, did it crank over?
Saturday, January 30th, 2021 AT 9:03 AM
C.PENTASUGLIA
Yes, I have tried this and the engine does crank? So it must be somewhere down the line from the ignition to the starter correct? When I turn the key I hear a noise from behind the glove box, its like a click. Click click. As I turn the key forward then bring it back? Any ideas?
Take it back to the starter relay, then the transmission position switch then the ignition switch -also check the crank fuse and ign fuse C
