1998 Chevy Blazer NOT STARTING
LIZARDI
  • 1998 CHEVROLET BLAZER
Engine Performance problem
1998 Chevy Blazer 6 cyl Four Wheel Drive Automatic
Has power and gas but no ignition. I have checked the fuses, spark plugs, timing belt, compression, firing order, and I even had a computer diagnostic on it and it will crank but not turn over. Not the battery either checked that throughly too, and even jumpstarted and nothing.
http://www.2carpros.com/forum/automotive_pictures/339788_easycareroses031_1.jpg
Friday, April 3rd, 2009 AT 8:50 PM
JDL
  • 16,098 POSTS
Hello, do the basic tests? Have a helper crank it, while you check for spark at the plugs. If you have spark everywhere, check fuel pressure.
Saturday, April 4th, 2009 AT 2:17 PM
LIZARDI
Yea we did that too. And more. We checked the spark, fuel pressure, belts, fuses, relays, and etc.
Monday, April 6th, 2009 AT 2:53 PM
JDL
  • 16,098 POSTS
Have you tried starter fluid in the intake, to see if the engine will hit? There can be a safety issue using flammable spray, that's your responsibility.
Does the valve train move, when you crank the engine, any cranking vacuum?
Monday, April 6th, 2009 AT 4:01 PM
