1998 Chevy Blazer Multi Cylinder Missfire
BILLMATHEWS6
  • 1998 CHEVROLET BLAZER
Engine Mechanical problem
1998 Chevy Blazer 6 cyl Four Wheel Drive Automatic
I have changed the spider and I still have the multi cylinder missfire. This does not happen all of the time but it does most of the time
Saturday, March 14th, 2009 AT 10:54 PM
Random/Multiple Cylinder Misfire Detected
What does that mean?Basically this means that the the car's computer has detected that not all of the engine's cylinders are firing properly.
A P0300 OBD DTC code indicates a random or multiple misfire. If the last digit is a number other than zero, it corresponds to the cylinder number that is misfiring. A P0302 code, for example, would tell you cylinder number two is misfiring. Unfortunately, a P0300 doesn't tell you specifically which cylinder(s) is/are mis-firing, nor why.
SymptomsSymptoms may include:
the engine may be harder to start
the engine may stumble / stumble, and/or hesitate
other symptoms may also be present
CausesA code P0300 may mean that one or more of the following has happened:
Faulty spark plugs or wires
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector(s)
Burned exhaust valve
Faulty catalytic converter(s)
Stuck/blocked EGR valve / passages
Faulty camshaft position sensor
Defective computer
Possible SolutionsIf there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.E. Spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.K.A. Coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
Random misfires that jump around from one cylinder to another (read: P030x codes) also will set a P0300 code. The underlying cause is often a lean fuel condition, which may be due to a vacuum leak in the intake manifold or unmetered air getting past the airflow sensor, or an EGR valve that is stuck open
Saturday, March 14th, 2009 AT 11:02 PM
