1998 Chevy Blazer lower intake gastket
1998 CHEVROLET BLAZER
75,000 MILES • 6 CYL • 4WD • AUTOMATIC
SLEN_1999
need some info on the does and don'ts when replacing lower intake gastket
Sep 18, 2010 at 5:28 PM
MADMIKE1735
  • 951 POSTS
its a pretty easy job, i recommend having a a repair manual for this vehicle with you before you tackle it.... also, invest in a paint marker... its useful for marking your distributor prior to removal... also, once you get your lower intake off, place a series of shop towels, or rags over the engine block to prevent most of your old gasket material from falling into your engine while your scraping it off.... hope this helps a bit.
Sep 24, 2010 at 7:23 PM
