I think you should check for bent push rods.A badly worn cam will do it as well, collapsed lifters. Try removing the rods and lifter, do a leak down test on the lifters, if you can choke the engine by hand, you are on the right track!
Wednesday, March 18th, 2009 AT 7:31 AM
