With the plug out of the PCM, look into it, remove the colored plastic retainer first. There are specific picks made for getting to the release tab. If you have a bright flashlight you will be able to see the tab on top of the connector, it needs to be pushed down or toward the opening of the terminal while gently pulling back
SPONSORED LINKS
Wednesday, January 16th, 2008 AT 7:41 AM
