1998 Chevy Blazer air controls
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
BLAZERONE
cannot get air flow to floor
Dec 17, 2007 at 4:52 AM
2CARPRO JACK
  • 11,533 POSTS
Check your vacuum source under the hood. Follow small black plastic line to engine, most likely is broken somewhere. Air coming out of the defroster is the default for a no source vacuum situation
Dec 19, 2007 at 4:33 AM
BLAZERONE
[quote:9a911c13d8="2CarPro Jack"]Check your vacuum source under the hood. Follow small black plastic line to engine, most likely is broken somewhere. Air coming out of the defroster is the default for a no source vacuum situation[/quote:9a911c13d8]
All other air controls work good. Where do I find the floor control module.
Dec 27, 2007 at 1:23 AM
2CARPRO JACK
  • 11,533 POSTS
My software doesnt show exacxtly which one it is.You can try looking under the dash and moving them by hand to see which one does what. Move selector, if one doesnt move but others do, that is most likely the one
Dec 27, 2007 at 11:40 PM
