it doesn't go into 4hi when I hit the button
1998 CHEVROLET BLAZER
KGDAD
Replaced electric 4wd actuator because of problems shifting from 4hi back to 2hi. Now it doesn't go into 4hi when I hit the button. But when I hit the 4lo button it shifts to 4lo with both 4hi and 4lo indicators lights on. What gives?
Dec 4, 2007 at 1:15 PM
2CARPRO JACK
  • 11,533 POSTS
Those two things arent related.The actuator probelm is 2 or 4 wd, high and low range is something to do with the transfer case.Start by checking all fuses.Do the range lights ever blink? Might need to put it in diagnostic to see if the PCM has stored a code. Dont need a scanner for this.
Turn ignition off for at least 6 seconds. Find DLC (diagnostic connector) bottom of dash near steering column d/s. Should be a diagnostic pigtail, (orange wire at DLC terminal 13), ground this wire, turn ignition to run position (engine off) and see if the indicators on the switch flash.If all blink once and stop, no codes. Otherwise count the flashes, there will be a 3 second delay between codes. Get back to me with results
May 14, 2021 at 5:24 AM
KGDAD
The range lights blink twice when I ground the terminal you suggested. I believe before this test, the lights would also flash twice while changing ranges although not entirely certain. I know prior to changing the actuator motor, there also was lights flashing. I understand now that the two problems are not related but changing the actuator motor did solve my problem going from 4hi back to 2hi. Just some FYI.
2CARPRO JACK
  • 11,533 POSTS
Code 2 is for the motor on the transfer case.Need to check all wires to the motor and connectors for damage/corrosion first. The TCCM (transfer case control module) Is behind the right kick panel. Need to check wiring from there to the switch and from the TCCM to the motor
KGDAD
Well, I was leaning toward the problem being of an electrical sort but I don't know what wires are suppose to be hot and when because I was lacking an electrical schematic for that circuitry. I have one now thanks to a friend but from what I gather of what you are suggesting, maybe I should just be concerned with continuity from switch to TCCM and TCCM to motor...correct? Also, you said the TCCM is on the right side kick panel...is that what I hear "clicking" when I change ranges? I was hearing it but couldn't find it. Thanks for telling me....it was driving me crazy looking for it.
EWOLDERN
This is the same problem as a the blazer that I am problably going to buy here in sweden has. I would very much like to know the answer to this problem when you find it out.
This seems like a very good forum, not easy to find help with american cars here in sweden sometimes, thanks!
/Erik
