1997 Chevy Blazer What the problem
167,000 MILES • 6 CYL • 4WD • AUTOMATIC
97BLAZER911
My car runs hot within 5 min. of me cracking it so i put water directly in the radiator and now it running normal but i know i havent fixed the promblem just gave it first aid. Also liquid is leaking inside the car on the floor of the passager side and i put a full qaurt of transmission fluid in and two days later the stick is bone dry, could that be whats on the floor inside me car? Could you tell me what the problem is?
Mar 2, 2009 at 7:28 AM
  • 31,937 POSTS
Hi there,
You have two problems here, first you bets get the cooling system pressure tested to locate any external leaks, i feel that the heater core is also faulty, secondly the transmission oil leak will be a seal or pan gasket leaking, have this inspected ASAP before you do some serious damage to the transmission.
Mark (mhpautos)
Mar 2, 2009 at 7:49 AM
JDL
  • 16,098 POSTS
As far as the leak inside the vehicle, has it rained recently? My next thought was the heater core, does the fluid look like antifreeze?
I don't know about the tranny issue, I don't think I ever heard of tranny fluid leaking inside the vehicle?
Mar 2, 2009 at 7:56 AM
