1997 Chevy Blazer timing
125,000 MILES • 6 CYL • 4WD • AUTOMATIC
MANDERSON1214
This is my daughter's vehicle I believe it is out of time. The head gaskets blew and then there was no spark to the plugs. Changed the head gaskets and put in a new distributor. Now the thing will crank over but will not start. The fuel pump is running and the filter is not clogged. If it is the time that needs to be set could you give me step by step instructions on how to do that. Thank you very much for your time and I appropriate anything you can tell me.
Aug 21, 2010 at 3:12 PM
  • 75,988 POSTS
Are you getting spark?
Aug 21, 2010 at 9:57 PM
MANDERSON1214
Yes, we do have spark now after putting in the new distributor.
Aug 22, 2010 at 5:41 AM
  • 75,988 POSTS
If you're getting the correct fuel pressure and injectors are pulsing-recheck the valve and ignition timing
Aug 22, 2010 at 7:33 AM
