While trying to start engine kicks back hard enough to strip the teeth off the flywheel.
Sunday, October 18th, 2009 AT 4:48 PM
MECHANIC
Have you checked timing? It sounds like it is too far advanced?
SPONSORED LINKS
Monday, October 19th, 2009 AT 7:20 AM
ESTRNGY
MEMBER
You're right on the money. I think that I've solved the problem. Seems that the crank shaft position sensor goes a little crazy and advances the timing up to 50degrees resulting in a no start, backfire, engine
kickback conditions. GM makes a revised sensor that
corrects the problem. Thanks again for quick responce
to my question.
Monday, October 19th, 2009 AT 12:03 PM
MECHANIC
Let me know if it fixes the problem.
Monday, October 19th, 2009 AT 1:25 PM
ESTRNGY
MEMBER
YES the problem is fixed. Installed a new crankshaft sensor timing is back to normal runs like new again.
Saturday, October 24th, 2009 AT 2:29 AM
MECHANIC
Sounds great. Glad you got it fixed. Let us know if you have questions in the future, and thanks for using 2carpros. Com
