1997 Chevy Blazer Losing Antifreeze
VORTEC43262
  • 1997 CHEVROLET BLAZER
  • 6 CYL
  • 120,878 MILES
Hi I just had my radiator, cap, water pump and fan clutch replaced as well as my thermostat. The Car seems to use a little antifreeze, and when it goes a little below normal I hear the heater core bubbling from under the dashboard but my carpet is not wet. I dont know if its the Head gasket, intake gasket or something else. It doesnt miss at all.
Wednesday, November 12th, 2008 AT 8:27 PM
MASTERTECHTIM
  • 4,750 POSTS
There must still be a leak, you will need to pressurize the cooling system and then you should be able to find the leak. Your parts store may have a loaner pressure tester you can use
Wednesday, November 12th, 2008 AT 8:41 PM
