1997 Chevy Blazer antilock brakes, power windows, heater fa
RICHLYNN
MEMBER
1997 CHEVROLET BLAZER
6 CYL
4WD
AUTOMATIC
116,000 MILES
What causes the windows and heater fan to not work when the dash brake lights come on and flash? This is intermittent.
Wednesday, May 21st, 2008 AT 5:27 PM
BMRFIXIT
MECHANIC
Check fuses and ground
check ignition switch
When it does it cycle ignition key few times noting if it will correct the issue and if so I would suspect the ignition switch
