The blazer won't start not unless I put gas into the throttle body. Then it runs fine. Has new fuel pump.
Monday, August 11th, 2008 AT 7:30 PM
MASTERTECHTIM
MECHANIC
Your connector on the fuel pump sending unit is bad, loose etc. If thats ok then the problem is most likely in the tank. When you replaced the pump did you replace the pulsator (connector from pump to sender) or did it come as a sending unit assembly? Did you use ac delco pump or afternmarket?
