1996 Chevy Blazer V6 Two Wheel Drive Automatic 195, 00 miles
HI, SIR
MY BLAZER HAD A BLOWN HEAD GASKET AND I AHD THE HEADS REPAIRD AND REPLACED BY MY HUSBAND AND THEY SAID THAT THAT THE OIL PUMP WAS GOOD IT WAS FULL OF THICK OIL ALL OVER ONCE TAKEN APART AND CLEANED OUT WITH GAS/AND KAROSEN GAS OIL DRAINED SEVERAL TIMES BEFORE DRIVING AND STILL CHANGING THE OIL SEVERAL TIMES BECAUSE OF THE CLEAN OUT IT STARTED FINE AND YES IT SMOKED BECAUSE OF THE SITTING AND GAS PURED IN IT AND RAN FINE, NOW IT IS KNOCING LOUD AND WHEN YOU PUSH THE GAS PEDAL IT CLACKS LOUDER AND WHEN YOU LET UP OFF THE PEDAL IT QUIETS DOWN AND THEN WHEN YOU TURN IT OFF IT KNOCKS RAPIDLY AND I STARTED HEARING A CLICK NOISE UNDER THE THE TRUCK ONCE IT IS RUNNING IN MY DRIVE WAY SEVERAL CLICKS IS THIS A CAM, OR LIFTER, OIL PUMP OR ENGINE GOING OUT I STILL DRIVE IT TO WORK AND I DON'T PUSH IT I DRIVE IT AS LIGHT AS I CAN I ALSO HAVE A STARTER PROBLEM ALL OF A SUDDEN TO WHERE THE STARTER KEEPS BREAKING @ THE BOLTS AND BRACKET MY HSBAND PLACED A WOOD BLOCK BETWEEN THE STATER AND MOTOR TO HEPL STAY IN PLACE CAN THEIR BE A BRACKET MADE FOR THIS CAN STOP MOVING THE STARTER FROM THE FLY WHEEL PLEASE GIVE ME SOME ANSWERS
THANKS S, DICKSON
SPONSORED LINKS
Wednesday, December 5th, 2007 AT 11:52 AM
