Engine Performance problem
1996 Chevy Blazer 6 cyl Four Wheel Drive Automatic
Where is the fuel pump located and what is the easiest way to replace it? Beside taking it to a dealer. NO MONEY have to do it myself. Thanks!
Friday, October 3rd, 2008 AT 2:35 PM
2CARPRO JACK
MECHANIC
Fuel pump is inside the gas tank. You have to drop the tank down out of the vehicle to replace the pump. There is no real easy way to go abou it. You will also need special release tools for the fuel lines on the tank unit, they can be gotten for cheap at any parts store. I know money is tight, but if you can do it I strongly suggest an A/C Delco pump. The cheaper ones are exactly that. Cheaper. They often dont work properly
SPONSORED LINKS
Friday, October 3rd, 2008 AT 7:24 PM
CHAGLUND
MEMBER
Thank you so much for the response and the information. I will do my best to find a delco pump to replace it with.
