1995 Chevy Blazer Will not start unless I spray starter flu
JRCAMP
  • 1995 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 252,000 MILES
The motor will turn over but will not start, like not getting fuel. I can spray starter fluid into the air inlet port and it will start-up and run very well goiong up teh road. I have replaced the wires, plugs and distributor cap. Could I have a leak in a fuel line in the plenum that is allowing the pressurized fuel leak out causing it not to start?
Monday, April 6th, 2009 AT 7:53 PM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation .. much appreciated
I would be checking fuel pressure from pump and the regulator ... hope this helps .. let me know !!
Fuel Pump
An in-tank electric fuel pump delivers fuel to injector(s) through an in-line fuel filter. The pump is designed to supply fuel pressure in excess of vehicle requirements. The pressure relief valve in the fuel pump controls maximum fuel pump pressure.
On CPI fuel systems, pressure regulator is mounted to fuel metering body inside intake manifold. On TBI fuel systems, pressure regulator is mounted on throttle body.
When ignition switch is turned to ON position, control module turns on electric fuel pump by energizing fuel pump relay. Control module keeps pump on if engine is running or cranking (control module is receiving reference pulses from ignition module). If there are no reference pulses, control module turns pump off within 2 seconds after ignition is turned on.
Most models also include a second control path through the oil pressure switch which will turn the fuel pump on after the switch detects oil pressure. Cranking time will be longer if fuel pump does not receive current until oil pressure switch contacts close.
Fuel Pressure Regulator (CPI)
A constant fuel pressure of 54-64 psi (3.8-4.5 kg/cm2 ) is maintained by a factory preset, nonadjustable, spring loaded diaphragm contained within CPI assembly. Spring tension maintains a constant fuel pressure to injector regardless of engine load.
Fuel Pressure Regulator (TBI)
A constant fuel pressure of 9-13 psi (.6-.9 kg/cm2 ) is maintained by a factory preset, nonadjustable, spring loaded diaphragm contained within throttle body. Spring tension maintains a constant fuel pressure to injector regardless of engine load.
Fuel Pump Relay
When ignition switch is turned to ON position, control module turns electric fuel pump on by energizing fuel pump relay. Control module keeps relay energized if engine is running or cranking (control module is receiving reference pulses from ignition module). If there are no reference pulses, control module turns pump off within 2 seconds after key on.
As a back-up system to fuel pump relay, the oil pressure switch also activates fuel pump. The oil pressure switch is normally open until oil pressure reaches about 4 psi (.28 kg/cm2 ). If fuel pump relay fails, the oil pressure switch closes when oil pressure is obtained, and operates the fuel pump. Cranking time will be longer if fuel pump does not receive current until oil pressure switch contacts close. Oil pressure switch may be combined into a single unit with an oil pressure gauge sending unit or sensor.
Control module monitors fuel pump circuit between fuel pump relay/oil pressure switch and fuel pump, enabling control module to determine if fuel pump is being energized by fuel pump relay or oil pressure switch. A failure in this monitored circuit results in the setting of a related trouble code in control module memory.
http://www.2carpros.com/forum/automotive_pictures/266999_AAA2_454.png
Monday, April 6th, 2009 AT 8:11 PM
SFBDBURBAN
  • 5 POSTS
The thing that I don't like about these forums is that the original person with the problem never responds AFTER they have their problem fixed. So I'm sitting here at 3 in the morning reading about TBI injectors not firing hoping to find an answer but just more dead ends.
Wednesday, May 27th, 2009 AT 4:58 AM
DAVE H
  • 13,384 POSTS
Hey SFBD
If you let me know your problem I would be glad to try and assist ??
http://www.2carpros.com/forum/automotive_pictures/266999_AAA2_740.png
Thursday, May 28th, 2009 AT 6:29 PM
