1995 Chevy Blazer timing
PETERANDDONNA
  • 1995 CHEVROLET BLAZER
Engine Mechanical problem
1995 Chevy Blazer 6 cyl Four Wheel Drive Automatic
when dropping distributor back in how far away from #1 tower should rotor be thanks
Friday, September 5th, 2008 AT 7:03 PM
BLACKOP555
  • 10,371 POSTS
You didnt makr the old distriubtor? If not you will have put the#1cylinder tdc on compression stroke, then the rotor should be lined up a little bit after the #1 cylinder since it already should have been fired.
Friday, September 5th, 2008 AT 8:47 PM
