1995 Chevy Blazer 95 S-10 Blazer
BLAZERGUY95
  • 1995 CHEVROLET BLAZER
1995 Chevy Blazer
my blazer takes a lil longer to crank. If I cut it off and crank it again it fires right up. It seems over time it gets a lil worse.
Friday, June 4th, 2010 AT 1:59 AM
Check the fuel pressure if its within specs and also test the fuel pump relay and coolant temperature sensor-if it continues to do this -test the ignition switch
Friday, June 4th, 2010 AT 2:32 AM
BLAZERGUY95
Where would the fuel pump relay and coolant temp. Sensor be located. Also how do you test the ignition switch.
Friday, June 4th, 2010 AT 3:01 AM
