1995 Chevy Blazer need help!
240,000 MILES • 6 CYL • 4WD • AUTOMATIC
FRALINS29
My tranny was shifting from first to second fine then would slip and not go into third. It would just rev up, So i then went and bought a tranny with 90,000 miles on it and had it put in. When i left the auto garage i noticed the same exact thing was happening. Completely different tranny and same thing. What could this be? It is a 95 chevy s10 blazer 4x4. could it be something elecrical or a solenoid? Please help!!!
Feb 3, 2009 at 7:37 AM
2CARPRO JACK
  • 11,533 POSTS
a 95 should be an L60E, so it is computer controlled on the shifts. There is a good chance that it is comp related if two trannies do the exact same thing
Feb 3, 2009 at 8:02 AM
FRALINS29
So where would you recommend I start troubleshooting? Somebody told me somethin about a shift control solenoid. Thanx
Feb 3, 2009 at 8:24 AM
2CARPRO JACK
  • 11,533 POSTS
All of the solenoids are inside the trans, so the chances of it being that in both are pretty slim. You may need to have a trans shop look at it, or another shop with the proper equiupment to control shifting via a scan tool . They will need to see if the computer is commanding a 3rd gear shift and if not they can do it manually to see if it works
Feb 3, 2009 at 8:29 AM
FRALINS29
OK. I did notice that when i bought the new trans it had a few wires coming out of it that were snipped, so they had to have use the old wires, that went to somewhere electrical out of the old trans. Could that be it?
Feb 3, 2009 at 9:13 AM
2CARPRO JACK
  • 11,533 POSTS
Salvage yards tend to just cut the wiring harness instead of unplugging them.I doubt that is the problem, remember this is the same issue with 2 trannies, the truck is the common denominator
Feb 3, 2009 at 9:43 AM
