1995 Chevy Blazer hello
ROGER007
  • 1995 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 12,018 MILES
How to connect the ABS motor?
Friday, May 28th, 2010 AT 1:58 AM
HMAC300
  • 48,601 POSTS
The connector may have a lever on it which should be in the up positionto install it. You place the connector in a little ways then push down on the lever and it will pull the connector in. The brake lines will connect justlike a wheel cylinder or master cylinder.
Friday, May 28th, 2010 AT 6:19 PM
ROGER007
  • 38 POSTS
What can I do the exact two connection of wire of ABS motor?
Friday, May 28th, 2010 AT 8:51 PM
HMAC300
  • 48,601 POSTS
If you need to wire it correctly then you need a manual to follow the color code as to where they go. Or if you just have two wires that are broken then you need to reapir them. Preferably with solder and shirnk tube. As well as the correct connectors.
Saturday, May 29th, 2010 AT 11:57 AM
