1995 Chevy Blazer ABS Brakes
1995 CHEVROLET BLAZER
70,000 MILES • 6 CYL • 4WD • AUTOMATIC
BARNETT806
brake pedal goes to floor. I had replaced rear brake line and the master cylinder and have bled all four wheels. The pedal still goes to the floor. I had it put on computer and was told to replace left front abs sensor. Can you tell me how to go about replacing it?
Feb 6, 2008 at 6:10 PM
JOHNYPHANTOM
  • 37 POSTS
remove tire , right above caliper close to strut will be a sensor about 2 inches long and as big around as a pencil , trace the wire back and unplug it , then remove bolt holding sensor in place , its pretty simple , just look at it and you should be able to figure it out ( disconnect negative battery cable before doing this )
Feb 6, 2008 at 6:50 PM
