Did you meant-the blower motor is on-but no heat at all-if so could be the thermostat.
SPONSORED LINKS
Sunday, November 30th, 2008 AT 8:32 PM
TRASCH37
MEMBER
Yes, there is no heat coming out at all, the heat went out while driving, not sure if the blower is working or not. The anti-freeze levels are good.
Sunday, November 30th, 2008 AT 8:41 PM
MECHANIC
If the blower motor is functioning-cehck the thermostat-if not it-could be an air mix/blend/mode door problems to include vacuum, actuators and the HVAC control module.
