Fuel pump relay?
MUGFORS
  • 1996 CHEVROLET BLAZER
  • 4.3L
  • V6
  • 4WD
  • 208,000 MILES
I just purchased this truck and cannot get it to run on its own.
It will run fine with ether in the throttle body, but dies once it burns off. It’s been sitting so I replaced the fuel filter. I swapped out the relays and still get nothing, cranks fine no power to the pump. I have not pulled the connector to the pump yet. It does have an aftermarket remote starter and alarm that I know nothing about, I plan on removing it, but I want to make sure it’s the issue first. New battery as well. Please advise as to where I should check and in what order.
Wednesday, November 6th, 2019 AT 3:31 AM
  • 109,901 POSTS
Hi:
Before you take the tank out to check the pump (which may be bad), confirm the fuel pump relay is bad. It is behind the glove box. Here are the directions for removal and replacement. Don't just replace it without checking it first. If there is another relay in the box that has the same part number, switch them or here is a link showing how to check one:
_____________________________
Here are the directions. That attached pictures correlate with the directions.
1996 Chevy Truck S10/T10 Blazer 4WD V6-4.3L VIN W
Fuel Pump Relay
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Pump Fuel Pump Relay Service and Repair Procedures Fuel Pump Relay
FUEL PUMP RELAY
pic 1
Fuel Pump Relay Retainer
Pic 2
Electrical Center Connector
Pic 3
Fuel Pump Relay
pic 4
REMOVAL PROCEDURE
NOTE: The relay center is located in the glove component.
1. If installed, remove the retainer.
2. Remove the electrical center connector.
3. Remove the relay by depressing the bracket clip at the rear of the relay or by removing the bolts from the retaining bracket.
INSTALLATION PROCEDURE
Is the reverse of removal
Wednesday, November 6th, 2019 AT 8:15 PM
STEVE W.
  • 13,597 POSTS
First thing will be to test the pump and it's wiring to see if it works. To do that go to the relay box under the hood. And look at the harness coming out of it, there will be a short Red wire that isn't connected to anything. That is the fuel pump prime connection. If you apply battery voltage to it the pump should come on. If it doesn't pull the fuel pump relay and you will see a diagram on it showing what the blades do, you want the ones numbered 30 and 87 Those are the feed to the pump and the battery feed from the ECM BATT fuse (#9). Take a test light and connect it to battery positive and touch those two contacts in the relay socket. On pin 30 the light should come on if the circuit through the pump is good as it will be a ground through the pump. If no light you have a problem in the Gray feed wire in the harness to the fuel pump. If it seems to work then connect the test light to ground and touch the 87 connector. This is the battery feed to the relay and the light should come on.
If those show good put a jumper across them and the pump should come on. If it does then you need to test the control side of the relay. Those are pins 85 and 86. With a test light connected to battery positive touch pin 86, it should light as this is the ground for the relay. Next connect the light to ground and touch terminal 85, then turn on the key, the light should come on for about 2 seconds. If it does the control side is working.
As it has been setting I would suspect either the pump connector to have corrosion (very common) or the pump itself is bad.
The other circuit that can verify this is to crank the engine until the oil light goes out or the gauge shows pressure. That will trigger the power feed through the pressure switch and send power to the fuel pump. If the pump doesn't come on in either case you will likely be dropping the tank to get to the pump connector and pump. You might be able to disconnect the pump pigtail without dropping the tank, if you can reach it.
Another test is to give the fuel tank a couple solid hits with a rubber mallet or similar, if the pump is marginal and sticking on a bad segment this can sometimes shock it enough that it starts working at least enough to test it, if it does start working this way do not trust it to keep working though.
Dropping the tank on these isn't that bad but you need to watch all of the vapor and vent lines as you lower it, and disconnect them as soon as possible. Be sure to replace the pump pigtail on the harness as well, they have a very bad habit of heating up and losing contact.
Wednesday, November 6th, 2019 AT 8:22 PM
MUGFORS
Thank you very much! You guys rock! I removed the no name alarm/remote start, verified the relays were good, then put power to the red wire under the hood. I loosened the straps enough to get the connector off the top of the replacement pump, and realized it was not attached to anything in the pump. The connection came off in the pump! I removed the pump and re-connected the wires and it is up and running on it’s own!
Thursday, November 7th, 2019 AT 2:19 AM
STEVE W.
  • 13,597 POSTS
Well that's a bit different. Glad to hear you found it.
Thursday, November 7th, 2019 AT 3:41 AM
EDCORTEZ2003
  • 6 CYL
  • 4WD
  • 132,000 MILES
I know where the relays are but there are three and they are not labeled. They are side by side horizantaly three in a row which one is the fuel pump relay? Far left, middle or far right.
Saturday, January 30th, 2021 AT 8:34 AM (Merged)
My info says you got 4 relays there and one of them is the F/P relay behind the glove box which one dunno.
DRL relay/Fog lamp/Horn
You sounded as though you're not getting power to the fuel pump-describe your problem maybe I can help-
CARLSHULL
  • 1995 CHEVROLET BLAZER
My wife has a 1995 chevy blazer 4x4, with 4.3l vortec, pushing 250,000 miles, have had little problem with until lately,
it started sputtering pretty bad, I replaced the fuel filter, fixed it for a day,
died on the road, had it towed back, dropped fuel tank, replaced fuel pump and pigtail wire on pump, was melted so was plastic fitting on pump, put it back together, started fine, I drove around block, seemed fine, came back, cleaned up, put my tools up, we left to go out, made it 4 blocks from the house, died, got it home, a friend of mine says he had pretty close to the identical problem, said it ended up being his fuel relay was stuck, so the fuel pump was constantly running, I guess,
my 2 problems,
first, which relay is for the fuel pump, there are 3 relays right beside each other on firewall behind intake,
second, since this died and has acted up again, do you think the fuel pump is shot or wiring melted again, I guess I should go ahead and drop the tank for safe keeping,
somebody give me some relief here,
my wife needs her truck and I need my sanity back?
Saturday, January 30th, 2021 AT 8:35 AM (Merged)
See below to locate the pump relay
https://www.2carpros.com/forum/automotive_pictures/12900_pumprelay1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_pump_relay2_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_oil_sending_unit_and_fuel_pump_circuit_14.gif
www.eautorepair.net
ADAMJ20
  • 5 POSTS
  • 143,000 MILES
I have a 1995 chevy blazer v6 4.3 vortec and it ran ok but we had to start it with starting fluid. We replaced the fuel pressure regulator and now it wont run for more than a few seconds. Everything is hooked up we replaced the fuel pump, map, maf, and tps sensors it seems like its not getting gas but theres no leaks. Checked the fuel pressure before and after fuel pump change and its the same 60 then it leakes down very quickly. The car is throwing codes 22, 34, and 43 for tps, map, and knock sensor. Could my knock sensor do this? Is there something else I should check?
HMAC300
  • 48,601 POSTS
1. Relieve fuel pressure. See FUEL SYSTEM PRESSURE RELIEF. Connect Fuel Pressure Gauge (J 34730 1) to fuel pressure connector. Turn ignition on. With ignition on and engine off,  pressure should be
54 64 psi (3.8 4.5 kg/cm2 ) and should hold steady.
2. If pressure is within specification and holds,  go to next step. If pressure is within specification but does not hold,  go to step 4). If fuel pressure is not present,  go to step 7). If pressure is greater than specification,
go to step 9). If pressure is less than specification,  go to step 5).
3. Start engine. With engine at operating temperature,  open throttle quickly and note fuel pressure. If fuel pressure is not close to64 psi (4.5 kg/cm2 ),  replace CPI assembly. If fuel pressure is close to 64 psi (4.5
kg/cm2 ),  problem does not exist.
4. Check for leaking injectors or fittings by pinching off fuel return line. If pressure does not hold,  replace CPI assembly. If pressure holds,  check for faulty in tank fuel pump or pump connections.
5. Check for restricted delivery line or fuel filter. Repair as necessary. If no restriction is evident,  apply battery voltage to fuel pump test connector using a 10 amp fused jumper wire. For location of fuel pump test
connector,  see COMPONENT LOCATIONS in SYSTEM/COMPONENT TESTS  4.3L article.
6. Gradually pinch off flexible fuel return line between CPI assembly and fuel tank. If fuel pressure increases to within specification,  pressure regulator is faulty. Replace CPI assembly. If fuel pressure does not
increase with line pinched,  check for faulty in tank fuel pump,  loose pump connections or partially blocked fuel strainer.
7. Use a 10 amp fused jumper wire to apply battery voltage to fuel pump test connector. For location of fuel pump test connector,  see COMPONENT LOCATIONS in SYSTEM/COMPONENT TESTS  4.3L
article. Observe fuel pressure reading. If fuel pressure is still not present,  check wiring between test connector and fuel pump. If wiring is okay,  replace fuel pump.
8. If fuel pressure is present with voltage applied to test connector,  test fuel pump relay and voltage supply to relay. See SYSTEM/COMPONENT TESTS  4.3L article.
9. Relieve fuel pressure. Disconnect fuel return line. Attach a 5/16" flexible fuel line to CPI side of fuel line. Route hose into appropriate container. Turn ignition on,  and note fuel pressure. If fuel pressure is within
specification,  locate and repair restriction in fuel return line. If fuel pressure is still greater than specification,  replace CPI assembly.
Also a new regulator doesn't mean it's good either. Also check battery and clean terminal ends. Load test battery. Check out the diagrams (Below). Please let us know what happens.
ADAMJ20
  • 5 POSTS
I just was able to try this, this is great! I plugged the return line and it held the pressure so were going to go try replacing the fuel pump again we could have got a bad one. But thank you very much this was very helpful!
HMAC300
  • 48,601 POSTS
Make sure your wires going to pum p inside tank are good as they have been know to fail.
ADAMJ20
  • 5 POSTS
So I tried this and we replaced the pump but it still is not holding the pressure. If return is plugged it holds but when let through it does'nt.
HMAC300
  • 48,601 POSTS
Only thing I can tell ya is try another fuel pressure regulator. Repeat steps 3-6 carefully and if it still doesit then i'd suggest taking it to a pro. Make sure you tell him everything that you have done though.
MICHAELLOVETT123
1995 Chevy Blazer 6 cyl Two Wheel Drive Automatic
i have a 1995 chevrolet blazer. I was told by a mechanic at a local shop that the problem to my truck was the fuel relay switch. Upon asking how to fix it, the man didn't know where the fuel relay switch was. Do you know where the relay is?
The fuel pump relay is in the convenience center see below
https://www.2carpros.com/forum/automotive_pictures/12900_fp_relay_9.jpg
CHARLIE_CRUZ
  • 6 CYL
  • 18,100 MILES
Where is the fuel pump relay located?
Saturday, January 30th, 2021 AT 8:36 AM (Merged)
Its in the convenience center see item no.3 for location
https://www.2carpros.com/forum/automotive_pictures/12900_fp_9.jpg
CBBECK
  • 4.3L
  • 6 CYL
  • 4WD
  • 338,553 MILES
Will not start fuse is good. Need to check relay next but don't know where it is
WRENCHTECH
  • 20,761 POSTS
It's located behind the glove box but this truck is designed to run without aq fuel pump relay.
https://www.2carpros.com/images/external/83268759.gif
