Hi 94fullsizeblazer,
Thank you for the donation.
What is the idling speed when the weather is hot?
Should not be a problem with vapor lock if the vehicle is running.
When problem occurs, check the fuel pressure if it could not be started. After restarting, does the problem occur again?
Saturday, July 17th, 2010 AT 6:10 PM
