1994 Chevy Blazer 94 S-10 Blazer starts then dies
FAEMTB2002
  • 1994 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 215,000 MILES
I have a 94 s10 blazer v6 vortec with cpi. I recently replaced the egr valve, map sensor, intake and return fuel lines because they were leaking, and the throttle position sensor. Now it will start then die suddenly and cant be started for awhile. What else can the problem be? I really need to get this truck runnng. I am a volunteer EMT and cant get to the fire station without it.
Tuesday, February 12th, 2008 AT 4:03 PM
MASTERTECHTIM
  • 4,750 POSTS
Will it start and run on starter fluid? If it does I would suspect the fuel pump pulsator and or pump located in the fuel tank. Get back to us.
Tuesday, February 12th, 2008 AT 6:36 PM
FAEMTB2002
Ok.I have fuel pressure and spark. Engine now cranks but wont start.
Saturday, February 16th, 2008 AT 11:59 AM
MASTERTECHTIM
  • 4,750 POSTS
If engine cranks but wont start then either you have fouled the spark plugs or there is not enough fuel volume (not pressure) getting to cpi. Try spraying starter fluid in it and see if it starts.
Saturday, February 16th, 2008 AT 1:57 PM
JRHARV03
  • 6 POSTS
Did you check for spark yet?
Sunday, February 17th, 2008 AT 10:30 AM
