1994 Chevy Blazer fuel pump
HARRY HOLLOWAY
  • 1994 CHEVROLET BLAZER
Engine Mechanical problem
1994 Chevy Blazer 6 cyl Four Wheel Drive 125, 00 miles
i've replaced my fuel pump two times and it still does the same thing it will work for about a month or less and then cut off last time I let it rest for about 7 hours and it started lasted another week with now it won't start could it be the fuel pump relay and where is that located at?
Saturday, July 18th, 2009 AT 2:59 PM
BUDDYCRAIGG
  • 2,262 POSTS
I see a common problem with 93-99 GM trucks a lot.
The female connectors in the fuse box under the hood, where the relay goes go bad.
They loose their "springiness" and don't have a firm grip on the blades of the relay anymore.
Saturday, July 18th, 2009 AT 9:39 PM
