Inspect for fluid leaks as a first step, remove the drums in the rear or calipers look under the dust boots of the wheel cylinders and or calipers, if fluid is dripping out there is a problem, or it could be if they are drum in back, he either install them wrong, or didnt adjust them. Tell me if you have drum or disc in the rear and we can dig deeper.
SPONSORED LINKS
Friday, March 19th, 2021 AT 12:25 PM
