2000 Chevy Blazer Brakes go to the floor
WEITZELFORD
Brakes problem
2000 Chevy Blazer 6 cyl Four Wheel Drive Automatic
The Master cylinder and the 2 front callipers have been changed and the brakes have been bleed. But the brake pedal steel goes to the floor?
Apr 22, 2008 at 3:54 PM
RHALL77
  • 3,361 POSTS
did you check to make sure none of your lines are leaking? are you sure you have all the air out of the system? did you bleed the rear brakes? also check the rear brakes. you may have a wheel cylinder leaking if they are drum brakes.
Apr 23, 2008 at 12:17 AM
XNOOKX
  • 24 POSTS
i took it in yesterday and had them changed and bleed and they still do it and the guy who worked on it said its prob;y a problem with the anti lock brakes
Jul 4, 2008 at 4:03 PM
RHALL77
  • 3,361 POSTS
does it have rear drum brakes. are you sure they are adjusted properly
Jul 7, 2008 at 12:46 AM
