my problem is that the vehicle will start and run fine for about 20 minutes then when I turn it off it will NOT restart unless I spray starter fluid in the throttle body or let it set for 30 minutes or so.
i have replace the fuel filter, I have checked the fuel pressure at the throttle body and it was fine (i dont remember the numbers right now) I am out of options here I dont know what else to check to find this problem
SPONSORED LINKS
Wednesday, April 15th, 2009 AT 12:39 PM
