Code 13, engine is sputtering and barely running?
CHEVYMETAL1991
I Have the vehicle listed above k5 (v10 4x4) blazer mileage 202,636 with a manual transmission. Last night it i started running really badly, it's sputtering and barely running. i ran the error code and it's coming up code 13 which is o2 sensor circuit open. i replaced the o2 sensor, but it still didn't help.
Jun 6, 2007 at 5:42 AM
BACKYARDMECHANIC
  • 337 POSTS
If you are still getting the same code, then I would check the wiring/harness to the O2 sensor. If the O2 sensor wasn't bad/open, then it is probably the wiring.
Jun 6, 2007 at 5:46 AM
  • 55,616 POSTS
Open wiring is the only thing that can cause this code or a bad ECM.
Dec 19, 2023 at 10:47 AM
