1997 Chevy Blazer P0336 No Start
PURPLEFROG
How do I repair a trouble code of P0336 on a 97 chevy blazer. It will not start. It has about 180,000 mile on it. The code is no crankshaft position sensor A circuit range/performance. We have changed a lot of things on here including the computer if you have any suggestions please let me know. Thank You!!
Jan 11, 2007 at 1:42 PM
INDYUKE
  • 416 POSTS
Have you changed out the crankshaft position sensor? Sometimes it's difficult to get them in position so that they can register where the crankshaft is, i.e. pick up a signal. Check the wiring to the sensor as well.
Jan 12, 2007 at 8:09 AM
Suggested Repair
Confirm the crankshaft position sensor was replaced and is seated so it can pick up the crankshaft signal, and inspect the sensor wiring.
Conversation Summary
The owner of a 1997 Chevy Blazer with about 180,000 miles reports a no-start and code P0336, crankshaft position sensor A circuit range/performance, after replacing several parts including the computer. The expert asks whether the crankshaft position sensor was replaced, notes that it can be difficult to position so it registers the crankshaft, and recommends checking the sensor wiring.
