1991 Chevy Blazer My door
NICOLIANO
  • 1991 CHEVROLET BLAZER
  • 4 CYL
  • 4WD
  • 220,000 MILES
Hi my question is about my passenger side door. It won't close. The piece that latches on to the metal post on the door sprung up. Is there a way to pull that piece back down or does it have to be replaced now?
Monday, September 20th, 2010 AT 9:07 AM
WRENCHTECH
  • 20,761 POSTS
It sounds like your latch is in the closed position. Simply grab a screwdriver and slip it behind the jaw while simultaneously lifting the door handle outside and it will pop open.
Monday, September 20th, 2010 AT 9:49 AM
NICOLIANO
Thank you so much, I will go give that a try now! I appreciate the help.
https://www.2carpros.com/forum/automotive_pictures/574856_Picture0086_1.jpg
[img]
Monday, September 20th, 2010 AT 10:47 AM
NICOLIANO
And I didn't need a man to help me! Some of us girls don't know a darn about cars and I just wanted to give the men in my life a break for a change and fix my own car problem. But, you are probably a guy but that's o.K! Now I just have to find the part that goes on the inside where the latch grabs a hold. The one on my driver side door is completely toast. You have a good day and thanks again so very much!
Monday, September 20th, 2010 AT 10:53 AM
WRENCHTECH
  • 20,761 POSTS
Being a girl has no bearing on anything. I talk to a lot of females that know a lot more about cars than some of the guys we see here.
Good luck
Monday, September 20th, 2010 AT 11:10 AM
