1998 Chevy Blazer door won't close
MISSLADY2U
1998 Chevy Blazer 4 cyl Four Wheel Drive Automatic
what do I need to replace on my door, it will not close or lock?
Jun 22, 2009 at 9:12 AM
SWILLIAMS
  • 597 POSTS
Sounds like the latch assembly has flipped OR the return spring has broken. With the door open look at the latch where the door striker pin enters it, If the latch has closed the slot will not be open. Stick a pen/screwdriver, whatever in the latch and hold the door handle open, rotate the latch open and see if the door closes now. If it does it again then consider removing and cleaning/lubing the latch OR replacing it.
Jun 24, 2009 at 4:12 PM
