1988 Chevy Blazer studdering
233,000 MILES • 6 CYL • 4WD • AUTOMATIC
TWINKIEDELIGHT05
  • 14 POSTS
Hi, i currently have a problem with my blazer while driving it at a low rps. The vehicle wants to studder and when it studders it throws my thing off in the transmision cause it slows down and then hurrys up and catches back up. was just wondering what would cause your engine to studder. thanks sondra
Sep 11, 2009 at 3:30 PM
  • 75,988 POSTS
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Sep 11, 2009 at 4:33 PM
TWINKIEDELIGHT05
  • 14 POSTS
are you saying for the 88 chevy hesitation problems that it could be these items wrong Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
_______________
or the ones that were at the top of what you had wrote me. thanks for the information
Sep 12, 2009 at 12:57 AM
  • 75,988 POSTS
Every one of them can cause your problem
Sep 12, 2009 at 7:11 AM
