Transmission wont shift. Its in first and it races and wont shift.
Feb 22, 2009 at 6:44 AM
CEDRICACKER
MEMBER
is the abs light on,how does it shift from a cold start?
Feb 22, 2009 at 10:35 AM
DSZLAMMER
MEMBER
My 1999 chevy blazar will rev up to 3000 rpm, shifts hard then takes off and my speedometer goes back and forth. This happens cold or warmed up. Yes the ABS lights are on.
Feb 23, 2009 at 9:13 AM
CEDRICACKER
MEMBER
Hey i have a 98 blazer mine acted the same way i had it scanned and found it to be the speed sensor on the left side of the transfer case that sensor if it goes bad will make your tranny go crazy it did mine
i would change that sensor my ABS light was also on make sure u disconnect the battery before u change it.
Feb 23, 2009 at 9:31 AM
CEDRICACKER
MEMBER
Let me know how it goes
Feb 23, 2009 at 9:32 AM
DSZLAMMER
MEMBER
Thank you for your help. We d/c the battery, changed the sensor. Now the transmission only races intermittently but not as hard. However the ABS light is still on? Any thoughts on that?
