Are you talking the ecm B fuse is blown? Unplug the oil pressure switch, see if it helps? There may be two such switches, one is located close to oil filter, for lite and or gage on the dash, the other is in the fuel pump circuit. Maybe located high on engine left rear. Note the wiring colors in the diagram.
You can unplug the relay, use a jumper with inline fuse from battery voltage to terminal for tan/white wire, if the pump runs without blowing the fuse, that part of the circuit is ok.
SPONSORED LINKS
Sunday, July 4th, 2010 AT 8:15 PM
