1984 Chevy Blazer Leaking antifreeze
DONCLARK
  • 1984 CHEVROLET BLAZER
  • V8
  • 4WD
  • MANUAL
  • 112,111 MILES
My truck started leaking antifreeze. It appears to be leaking from the front of the intake manifold in the gasket area. It is leaking pretty quickly. Is this a common place for this old 350 engine to leak from? Could you tell me something about this? Thank You
Sunday, March 2nd, 2008 AT 10:23 PM
PEAR69
  • 1,482 POSTS
Congradulations! You are the 7 billionth or trillonth person to have this problem. Lol
Yes this is a common problem. I am suprised, it seems that you never had this problem with this truck after over 20 years. All kiddin' aside you should fix this problem soon because it will only get worse and the coolant leak could began (if it hasn't already) to leak inside of your motor. If this happens it will cause catostrophic engine failure.
Monday, March 3rd, 2008 AT 3:31 AM
