Hello !
Well, you have to be sure where its leaking from.
Most of the case its the fitting where the hose connects, get corrode or the hose clamp"cuts" trough the hose and its hard to see it.
Get a flashlight and move the heat selector to cold (that way you buidl up pressure and you will see the leak.
Good Luck!
Friday, November 16th, 2007 AT 2:09 PM
