1996 Chevrolet Beretta Service Engine Soon
JACKNDOLLY
my son has a 96 chevy beretta that has a "service engine soon light" that i'd like to reset. he's too lazy to go buy a chiltons manual, and i'm too smart to buy it for him since he'll never use it. could you fella's help an old shade tree mechanic out and tell me how to reset it please?....Jack
Jul 14, 2007 at 1:13 PM
E40WATER12
  • 522 POSTS
Since you got check engine light on, I would go to youre local autozone and have them scan, The trouble code, Once you replace the broken sensor, Should correct the problem.
Jul 14, 2007 at 7:42 PM
FOXYTIGER
  • 25 POSTS
go to autozone they should be able to reset it or tell you how i would checkthe codes first if they tel you it to old keep looking for someone to read them they would only do mine a the main 24hr store and oreily is suppose to get one that will read it if your car is newer you shouldnt have a problem getting it checked ive heared something about takeing off the battery cable then hitting the brakes 3 times dont know if that works or not and im not sure if you hit the brakes 3 times before or after you put the battery cable on it think they said after reconeccting then hit the brakes 3X ?? oh and if you dont fix whatever it was in the first place its not going away
Aug 17, 2007 at 9:36 AM
Suggested Repair
Have the service engine soon codes scanned at a parts store such as AutoZone, then repair or replace the failed part the code identifies. Resetting the light alone will not keep it off if the fault remains.
Conversation Summary
The owner of a 1996 Chevrolet Beretta wants to reset the service engine soon light. An expert advises scanning the trouble code at AutoZone and replacing the failed sensor once identified. Another reply agrees to check codes first and mentions an unverified battery-disconnect reset method, warning the light will return if the underlying problem is not fixed.
