Power Steering out
HAVRE
  • CHEVROLET BERETTA
95 Beretta V6, 175,000 miles - My power steering recently went out. It worked when I first started the car up, then there was a smell like something was burning and shortly after I had no power steering. I'm thinking that hopefully it is an issue with the belt, does this sound right? Where should I look for this belt and should it be relatively easy to fix myself? Other sugestiions welcomed as well.
Monday, October 15th, 2007 AT 12:09 PM
BOOTDOG
  • 665 POSTS
Yes I do believe the belt broke. Also find the reason why it broke. Look for any pulleys that may have seized causing the break. Good luck to you
Monday, October 15th, 2007 AT 4:11 PM
