battery keeps dying
DBHB357
I have a 1992 beretta and the battery keeps dying in it.. the battery is new and if the car sit for 7-8 days the battery will die.
please help
Aug 24, 2007 at 4:15 AM
SERVICE WRITER
  • 9,123 POSTS
it sounds like a parasitic draw, meaning there is an excessive draw on the battery. The draw on the battery should be less than 30 milliamps. Check the draw with a DVOM and pull a fuse one at a time until you see the draw fall into the acceptable range, then check that fuses circuit.
Aug 24, 2007 at 4:56 AM
