cutting out
CHEVROLET BERETTA
JASON4201979
I have a 1995 beretta 3.1 motor with 142,000 miles.
I just replaced the cattilict convertor. It is still cutting out when you leave off the gas but does not shut off. It idles fine and runs good what could be causing it to cut out when I am leaving off the gas.
Sep 3, 2007 at 9:59 AM
BLACKOP555
  • 10,386 POSTS
sounds like your idle needs to be turned up a bit to see if it runs better, if not your IAC module or PCV valve could be bad.
Mar 21, 2008 at 10:34 AM
SPADE007
  • 37 POSTS
[quote:1028c725d8="Jason4201979"]I have a 1995 beretta 3.1 motor with 142,000 miles.
I just replaced the cattilict convertor. It is still cutting out when you leave off the gas but does not shut off. It idles fine and runs good what could be causing it to cut out when I am leaving off the gas.[/quote:1028c725d8] check the egr valve
Mar 23, 2008 at 10:26 AM
