1995 Chevy Beretta Water pouring from engine
DEMER1206
  • 1995 CHEVROLET BERETTA
  • 6 CYL
  • 144,000 MILES
There is water/antifreeze pouring from the "rear" of the engine. The place that the water is coming from is a little plastic tube with an eblow shaped rubber boot on it. It looks as if maybe a hose or tube of some kind should be plugged into the boot, although I couldn't find anything that looks like it came out of it. Above this place where the water is coming out, there are a couple of "high pressure"? Hoses (with steel ends) attached. Would this be something for the heater core?
Wednesday, August 13th, 2008 AT 5:08 PM
  • 109,758 POSTS
Hi:
It could be from the heater core, but the description doesn't sound like it. The rubber hose that you describe doesn't sound like a cooling system hose. It sounds like the drain for the AC.
Is there any way you could take a picture with a digital camera and send it to me?
Thursday, October 30th, 2008 AT 7:33 AM
