Use a pair of jumper cables attach positive to starter terminal, negative to engine block, try to start, if it now starts, one or both of your battery cables is no good. If this fails, try turning motor by hand at the crank pulley. Remove plugs to make it easier.
SPONSORED LINKS
Friday, December 25th, 2009 AT 9:01 AM
