HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Beretta
Engine
Symptoms
Not Running
SPONSORED LINKS
1993 Chevy Beretta won't start
ELEEBACK
MEMBER
1993 CHEVROLET BERETTA
4 CYL
FWD
AUTOMATIC
55,000 MILES
Have spark, fuel pump is working, won't start
Wednesday, June 9th, 2010 AT 1:59 PM
MECHANIC
Check the fuel pressure to rule out the fuel pump and also if the injectors are pulsing
SPONSORED LINKS
Wednesday, June 9th, 2010 AT 3:49 PM
ELEEBACK
MEMBER
Yes, I have fuel line pressure, and pulse to injectures
Wednesday, June 9th, 2010 AT 5:04 PM
MECHANIC
Is it the correct fuel pressure? If so check the valve and ignition timing
Wednesday, June 9th, 2010 AT 6:11 PM
ELEEBACK
MEMBER
It has an ECM and hydraulic valves, fuel pressure is correct.
Wednesday, June 9th, 2010 AT 6:26 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1993 Chevy Beretta Crank No Start
Electrical Problem 1993 Chevy Beretta 4 Cyl Front Wheel Drive 145000 Miles I Think My Coil Went Bad However I'm Not Sure Where It Is...
Asked by
bruce deel
1993
CHEVROLET BERETTA
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1993 Chevy Beretta Seems To Not Be Getting Any Fire
Engine Mechanical Problem 1993 Chevy Beretta 4 Cyl Two Wheel Drive Automatic Had This Car Sitting For About A Year, Finally Got...
Asked by
redbudslim
1 ANSWER
1993
CHEVROLET BERETTA
93 Beretta Tension Pulley
How Difficult Is It To Replace The Belt Tension Pulley On A 1993 Chev Beretta 3.1. I Have Read Somewhere That You Have To Go Through The...
Asked by
aceshigh717
1 ANSWER
1993
CHEVROLET BERETTA
1988 Chevy Beretta Car Will Crank Over But Not Start
Car All Of A Sudden Died On Me While Driving. No Check Engine Light, Nothing. Killed Battery While Trying To Tow It And Disconnected...
Asked by
l.jaski
1988
CHEVROLET BERETTA
Car Wont Start Right Away, But Cranks.
My Car Wont Start Right Away, It Cranks And After A Lot Of Cranking It Will Finally Fire Up. Once It Has Been Started, It Has No Trouble...
Asked by
kshawkeye
1995
CHEVROLET BERETTA
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
