1990 Chevy Beretta STALL AND WON'T RESTART
ZOOMLAOS
  • 1990 CHEVROLET BERETTA
Engine Performance problem
1990 Chevy Beretta 6 cyl Front Wheel Drive Automatic
i have a 1990 cvehy beretta st V6 3.1 it start and run great when it stall it won't restart. So I replace the coil pack and it still doing the same thing so I replace spark plugs and fuel filter and fuel pump I check fuel pressure it ok can you give me and I dear what can sause this problem. Thank you in advance for your help
Monday, November 2nd, 2009 AT 2:55 AM
Do you hear the fuel pump come on when you turn key to run/on? If so check the fuel pressure if its within specs and also check for injection pulses. If okay check for spark-
Monday, November 2nd, 2009 AT 3:10 AM
