1989 Chevy Beretta Rough Idle Idles up and down RPM's
1989 CHEVROLET BERETTA
87,000 MILES • 6 CYL • 2WD • AUTOMATIC
MYERSRANGER
Rough Idle. Idles up and down on RPM's Gauge.
Does it need a Idle Speed Control? What Corrective Action Needs to be Taken. Also What Parts are Needed for a Complete Tuneup?
Oct 26, 2009 at 8:35 AM
  • 110,240 POSTS
Before replacing anything, has the check engine light come on? It could be a throttle position sensor (TPS) or idle air control valve (IAC) or as simple as a vacuum leak. Without a check engine light and trouble code, it becomes a guessing game.
Take the car to a nationally recognized parts store if the light is on and have them scan it. Most will do it for free.
As far as a tune up, spark plugs, plug wires, distributor cap and rotor. I usually like replacing the fuel filter and checking the air filter and PCV valve.
Let me know what you find with the light.
Oct 30, 2009 at 3:00 PM
