1989 Chevy Beretta 6 cyl Front Wheel Drive Automatic
I have a 1989 beretta 2.8 auto It will start then dies it has 45 lbs fuel pressure new ECM new TPS new idle air control new plugs and tried coil& engine control mod, map sensor, crank angle sensor from a running beretta same year and motor still the same I don't know what else to try no codes where on the old ECM or new one after trying to start it sometime it will idle low and rough but die if you touch gas feed. Please let me know if you can help. Thanks
SPONSORED LINKS
Wednesday, April 15th, 2009 AT 11:44 AM
